Darkshadow1029
May 03, 2017Aspirant
Just bought a nighthawk x6 r8000 and can't get it to install
I hooked it up lick the quick start manual said. Powered up like it said. The genie setup started then went no where. So I finally told it I would setup myself. Now it won't take the user name and pas...
- May 04, 2017
had to call tech support. they had me go into the manual setup, and change the Mac setting too use my computers mac and restart the modem and router. worked like a charm.
Darkshadow1029
It's still not working. It keep saying problem detecting the inter connection. Choices are I just power cycled the modem. Or I corrected a problem with the Ethernet cable. I using one out of the box.
May 03, 2017Guru - Experienced User
What is the Mfr and model of the ISP modem?
