Help
3 TopicsNighthawk 6700v2 Not Working pls help :c
Ok, So I receieved my Nighthawk 6700v2 router today and was excited to set it up. :C then it hit the fan. This might be far fetched for most of you as it is in New Zealand, but nevertheless: my ISP is Spark and I am currently on a Fibre 100 Plan. This of course comes with a 'fibre box' which is mounted on the wall and has my router connected to it. However, when I take out the ethernet and put it in the nighthawk, configure the settings appropriately, firmware update; nothing. I performed a self diagnosis and found that the issue is transferring the broadband (internet i think) from the fibre box to the nighthawk. Is this a compatability issue? Can I fix it? Or should i just get a refund? I ordered the nighthawk from US Amazon, so is that the reason? What do i dooooooo?:C Thanks in advanceSolved5.8KViews0likes9CommentsNighthawk X8 R8300 wifi comnected but no internet
I upgraded to a new netgear Nighthawk X8 Model E8300. New in the box un opened. Opened it up and Pluged in the internet from the modem with a 25ft Insignia Either cable rated for 1000MBS. I can hook up to the WIFI but am recieving no internet. Called the provider and was told all is good on their end. All lights are green on the Modem, reset the modem. I have the genie app and hit the reboot router, let it reboot still have no internet. I hit the reset button on the router and re-set the factory pasword on my phone back to the factory router pasword, hooked back up and no internet. I thought the new cable was bad so I used the one that came with the new router. Unpluged the router and moved it closer to the modem to use the 3 ft cable. Pluged it in and waited for it to boot up. Hooked up to the router and no internet. Any help would be appriciated. I can hook up my TV, Tablet and phone but all three say connected to network but no internet.SolvedJust bought a nighthawk x6 r8000 and can't get it to install
I hooked it up lick the quick start manual said. Powered up like it said. The genie setup started then went no where. So I finally told it I would setup myself. Now it won't take the user name and password off the bottom. What do I do?Solved5.5KViews0likes15Comments
