Darkshadow1029
May 03, 2017Aspirant
Just bought a nighthawk x6 r8000 and can't get it to install
I hooked it up lick the quick start manual said. Powered up like it said. The genie setup started then went no where. So I finally told it I would setup myself. Now it won't take the user name and pas...
- May 04, 2017
had to call tech support. they had me go into the manual setup, and change the Mac setting too use my computers mac and restart the modem and router. worked like a charm.
Darkshadow1029
A Cisco dpq3212
May 03, 2017Guru - Experienced User
Ok, making sure your ISP modems doesn't have a built in router. It doesn't.
The R8000 should connect up. Might swap out LAN cables between the router and ISP modem and try again.
I recommend you phone contact your regional NG support office for more help and information on this as well.
