Darkshadow1029
May 03, 2017Aspirant
Just bought a nighthawk x6 r8000 and can't get it to install
I hooked it up lick the quick start manual said. Powered up like it said. The genie setup started then went no where. So I finally told it I would setup myself. Now it won't take the user name and pas...
- May 04, 2017
had to call tech support. they had me go into the manual setup, and change the Mac setting too use my computers mac and restart the modem and router. worked like a charm.
Darkshadow1029
Can't find a phone number for them.
- FURRYe38May 03, 2017Guru - Experienced User
Id Start here and select the "Get help on my NETGEAR product" link. And walk thru this...
http://www.netgear.com/support/contact.aspx
NG doesn't make it easy to find the number.
Or send ElaineM a PM here in the forums.
