markyac's avatar
markyac
Lost WIFI on R6900v2
Hi all,
WIFI was working fine and in the last hour or so, just stopped.  Model R6900v2.   I have powered OFF/ON both Modem and Router several times.  I can log in via routerlogin.net if that helps.
Lights are now as follows:
Power - Steady White
Internet - Flashing White
2.4 - OFF
5 - OFF
Guest - OFF
USB - OFF
1 - Flashing White
2 - OFF
3 - OFF
4 - Steady Amber
Any ideas?  Internet via cable from Router to Modem works fine.  Internet is fine.  Help?!  :)
  • markyac wrote:
    You seem nice.
    Sorry about that.
    When you did the power cycling did you do it in the right order?
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it connect.
    • Turn on computers and rest of network.
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
    Check the section that deals with troubleshooting with the LEDs.
  • > 2.4 - OFF
    > 5 - OFF
       Might be a hint.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  Pay particular attention to the
    "WiFi On/Off button with LED".  Did you press it?  (Further reading
    might be helpful, too.)
      • michaelkenward's avatar
        michaelkenward
        markyac wrote:
        You seem nice.
        Sorry about that.
        Support | NETGEAR
