sktn77a
Aug 03, 2021Virtuoso
Maximum internet connection speed of R7000?
Hello there! I have 5 Netgear R7000 routers (don't ask). They have given stellar sevice over the last 5 years or so. I had Spectrum 200down/10up for all this time and never had any issues with dow...
sktn77a
Aug 04, 2021Virtuoso
Thanks for the suggestions. No speed sapping options selected. Using speed.googlefiber.net, speedtest.net, fast.com, all the same and all give the full speed when the router is out of the curcuit. I'm using F/W v1.0.9.42 - yes, I know it's an older version but it has features I want and I'm not convinced that "updating to the latest firmware" is going to change anything. I might just give it a try as I can drop back to the older firmware, it just seems like a waste of time reading all of the relevant posts on this forum.
Are you getting gigabit internet speeds on your setup?
sktn77a
OK, so I broke down and updated the firmware on one of my routers. :smileyfrustrated: Speeds are a little better now (600 down, 400 up) but still not the 930 up/down that I get without the router in the circuit.
So, my original question is.... does anybody get gigabit (900+) dow/up speeds with their R7000 router?
- antinodeAug 04, 2021Guru
> [...] I [...] updated the firmware on one of my routers. [...]
As always, an actual version number would be more useful than your
opinion of what's "updated" today. And, on an R7000, its own opinion is
worth very little.- sktn77aAug 04, 2021Virtuoso
"And, on an R7000, its own opinion is worth very little."
Not following you here, bud (?)
Firmware was update from 1.0.9.42 to 1.0.9.88 - the latest version available from the router interface (yes I know there's a more recent on on the support website, but is there a reason the router won't let you update it to this one? Who know with Netgear!)
Follow the link?
> [...] is there a reason the router won't let you update it to this
> one? [...]"won't let you"? How, exactly, does it _stop_ you?
> [...] I know there's a more recent on on the support website [...]
So, ...
> https://community.netgear.com/t5/x/x/m-p/2069376#M186506
Spreading this waste of time across multiple threads might not be the
most efficient approach.
