sktn77a
Aug 03, 2021Virtuoso
Maximum internet connection speed of R7000?
Hello there! I have 5 Netgear R7000 routers (don't ask). They have given stellar sevice over the last 5 years or so. I had Spectrum 200down/10up for all this time and never had any issues with dow...
antinode
Aug 04, 2021Guru
> Not following you here, bud (?)
Follow the link?
> [...] is there a reason the router won't let you update it to this
> one? [...]
"won't let you"? How, exactly, does it _stop_ you?
> [...] I know there's a more recent on on the support website [...]
So, ...
> https://community.netgear.com/t5/x/x/m-p/2069376#M186506
Spreading this waste of time across multiple threads might not be the
most efficient approach.
sktn77a
Aug 04, 2021Virtuoso
It's not an option in the GUI to update beyond 1.0.9.88, so you have to do it manually if you want to go higher.
"Spreading this waste of time across multiple threads might not be the most efficient approach."
It wasn't spread until you asked and "waste of time" is just your opinion.
Tell you what, just don't respond to any more of my posts - we'll both be happier.
:smileyhappy:
- antinodeAug 04, 2021Guru
> to do it manually if you want to go higher.Does "do it manually" _not_ use "the GUI"? Would you be pushing the
bits into the router with your fingers?
