hakunamatata202's avatar
Apr 20, 2022
Missed 5Ghz channel all of a sudden for R6700V3
I suddenly am no longer able to see my 5Ghz channel in my list When I initially set it up I had 2.4Ghz and a 5Ggz channels.
It had been running fine since I got it (a little bit more than a year), then all of a sudden it's missing.
I can see the 5Ghz light on the router and the router dashboard also looks ok to me.
I tried restarting the router to factory setting but it didn't solve the issue.
And there's no "Enable smart connect" that will merge 2.4 and 5 together so I highly doubt the issue.
I'm not sure what else I can try.
Thank you in advance for the help.
  • plemans's avatar
    1. what version of firmware are you on?
    2. have tried multiple devices?
    3. have you named your 5ghz something separate from the 2.4ghz?
    4. Have you tried using a wifi scanner to check it and not just the built in utility?
    • Thank you for the reply !
      V1.0.4.122_10.0.95
      Yes, I have tried it on multiple devices
      Yes, I have named it separately.
      I tried using a wifi scanner both laptop and phone and it's not showing up too.
      • plemans's avatar
        have you tried changing the 5ghz channel?
        Or trying a factory reset? (not reboot, but a full reset)
