Retired_Member's avatar
Retired_Member
Dec 15, 2021
MK63-MR/MS-60 Connectivity Issues
Recently picked up a Netgear Nighthawk Mesh WiFi MK63 system and am having a surprisingly hard time connecting the 2nd sattelite. I've spent a good amount of time in here reading about similar issues and tried to cherry pick some support where possible. I ended up manually updating the BIOS to V1.1.6.122_2.0.58 on the router and on both sattelites. I also sync' them all in very near proximity. The router is on my second floor, and have two sattelites spread across no more than 25 feet on the main level.   One of the sattelites ONLY connects when the backhaul ethernet is plugged in to the router. The moment I unplug it and move it back down to the main level is vanishes and leaves a solid amber light. Any tips? Suggestions?
The network setup is fairly simple: Cable Modem & Router -> MR60 -> MS60s
