sparkles_2014
Jul 27, 2016Aspirant
model ac1900 wi-fi is turned off
Up until a week ago, router was working fine; for some reason wi-fi is shut off - i contacted support and did recommendations but nothing worked. The unit was purchased in 2012 - I'm trying to decide if I need to purchase a new unit. I don't want to pay $49 for a service only to find the unit is not worth repairing. I'd rather use the money toward a new unit. I rebooted the unit by punching the "hole" on the unit but all it did was turn off the internet.
My internet provider was out yesterday and the signal was fine - I'm getting the internet on my main computer, and the router is set at the moment on ETHERNET. However, because wi-fi is not working I'm not gitting signals on my other devices, like laptops and notebooks. When I pull up settings my wi-fi shows other people's sites but not mine. Also, the proxy server is turned off and not working. I need help and advice.
Purchased new router; as I said, old one no longer functions and cannot be fixed. I appreciate everyone's help, but sometimes you just can't raise the dead.
- Anonymous
sparkles_2014 wrote:I rebooted the unit by punching the "hole" on the unit but all it did was turn off the Internet.
Try pushing reset until power Led flashes instead of punching the hole, If done correctly the router will default to factory settings.
These default setting are located on router label, if the WIFI default SSID is not present then replace it.
- sparkles_2014Aspirant
??? The hole is the reset button, the only other button on the back of the unit is the on-off buttton. I don't understand - I've already contacted support, and did everything they asked. Where is the reset you are referring to? I think the problem is more complicated than simply reset, but then I'm not computer savvy. Thanks for the reply.
- IrvSpMaster
There is a button on the top of the router, is that pressed in? That will turn off the signal.
Use a browser and check if the wireless SSID is on. It needs to be on to see the SSID. It might be off.
- Anonymous
The manual states in default settings, Wireless and SSID broadcast are on , so A reset to default factory settings if done correctly should override the front button. Mine is working fine so I don't want to test it.
- Anonymous
2nd led/button from top right is radio off on switch too. Try reading the manual!
