Aaron_Beal
Aug 06, 2021Follower
Model C6900 Firmware
Firmware for my Modem Router is apparently out of date. I bought this new and my firmware is several versions behind ... I own this modem outright, my service provider technician says I need to download and update the firmware. However this site is saying I need to talk to the service provider download the update. so Im stuck ... How can I download the latest version update my router.
My version is dropping a 400Mbps speed down to an unusable 160Mbps Wifi becasue of outdated firmware. Service provider techniician tested 450Mbps incimmoing speed and 450Mbps (tested onsite by a Tech and remotely). Modem/Router Netgear-5G wont let me get more than 150-200Mbps. Technician is telling me my firmware needs to be updated.
Why doesnt Netgear doesnt offer a download/update? This is rendering my unit to substandard speeds ... what are my options?
1 Reply
Not really.
There is a bug in the current iOS Nighthawk app.
Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
Note the Netgear response:
Re: Nighthawk app same "firmware not updated" when... - NETGEAR Communities
Netgear cannot offer firmware downloads for cable modems. You cannot update it.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
What makes you think the speed is "substandard"? If it is, then your ISP is responsible.
This issue has come up several times in the appropriate section for your hardware:
