BrainierGecko3's avatar
Nov 14, 2020
My internet connection is 300 mbps but my router is doing 49 now?
I thought it was the modem, but speed test shows that without the router, I'm getting between 317 and 343 mbps. With the router, it was 80. Then I unplugged the router and got the solid orange globe. Then I held down the reset button for 30 seconds and pulled out the power supply and then kept holding it down as I plugged the power back in. No orange globe. Now the speed is down to 49. What is going on?
  • > Model: R6080|AC1000 Dual Band WiFi Router
       Firmware version?  Connected to what?
    > [...] without the router, I'm getting between 317 and 343 mbps. With
    > the router, it was 80. [...]
       If you have an R6080, then speeds over 100Mb/s would be astounding.
          https://community.netgear.com/t5/x/x/m-p/1711958
    > [...] What is going on?
       I don't know.  Perhaps you should stop trying to invent new
    settings-reset methods in attempts to remove a hardware limitation.
    • BrainierGecko3's avatar
      BrainierGecko3
      Didn't invent it. I found it as a possible solution. I was getting  over 300 mbps just 48 hours ago.
      • antinode's avatar
        antinode
        Guru
        > [...] I was getting over  300 mbps just 48 hours ago.
           Through an R6080?  I don't see how.  (Note: "m" = "milli" = 1/1000.
        "M" = "mega" = 1000000.)
  • Is the router connecting to your devices via WiFi or CAT cables ? WiFi will always be slower than a cable connection and it matters if its 2.4 or 5 ghz band with WiFI. Some devices such as smart phones will not reach full download speeds due to WiFi and make of phone as some have lots of power and some phone are weak. Best to test any device with wired connections first and if up to speed, the rest is WiFi interferance and connecting devices, most likely.
    • michaelkenward's avatar
      michaelkenward
      Up to a point.
      The issue here is that the modem cannot go faster than 100 Mbps with an Internet connection.
      When it comes to the wifi, it may be possible to make a measurement faster than that between two devices on the local wifi network. But you won't get more than 100 Mbps with wifi that connects to the outside world with the internet.
      • gsuburban's avatar
        gsuburban
        Tutor
        The 10/100 hardware is old stuff and should be replaced with 10/100/1000 LAN ports and if you are a cable customer, check into channel bonding and buy a modem that supports the highest channel bonding such as 32x8 and is no less than DOCSIS 3.0. If you rent the ISP modem, they should upgrade you to their newest modem at no cost. Some of this information is avaialbe on your ISP website. You will of course benefit with faster speeds and also with more security advantages with newer hardware. Modems tend to be outdate after 5 years of age. Have you logged into the firmware on this router to confirm settings?
