radio_chas's avatar
radio_chas
Follower
Feb 12, 2018
My laptop computer does not have an ethernet port.
My laptop has no ethernet port.  Can I connect to the router via the USB 2.0 port to upgrade the firmware, although it is marked printer on the router?
What other options do I have?
  • antinode's avatar
    antinode
    Feb 13, 2018
    > [...] download the new firmware to a USB stick and flash from that.
       Please explain what that means.  How does using a USB storage gizmo
    help matters?
    > Just follow the Release Notes.
       I don't see anything there about a USB storage gizmo.  All I see is
    "[...] download and extract the new firmware to a convenient place such
    as your desktop."
    > You can upgrade firmware over wifi.
          Firmware upgrade instructions:
          Note: To avoid disconnect issues during the firmware download
          process, NETGEAR recommends the firmware update be performed on a
          computer with wired connection.
  • > My laptop has no ethernet port.
       What is your "My laptop"?  Can you attach an Ethernet interface to
    it?
       It won't work.  The router firmware supports only printers and
    storage (not networking) on the router's USB ports.
       Make friends with someone whose computer has an Ethernet port?
    • antinode's avatar
      antinode
      Guru
      help matters?
      as your desktop."
