BlueWonder's avatar
BlueWonder
My R7000 bricked during update to V1.0.9.18_1.2.27
During upgrading my router something went wrong.
Now I can not connect to my router.
Even trying to reset or reflash with tftp will not work.
What to do?????
  • A friend had the solution.
    I used TFTP2.EXE on my laptop (Windows 10).
    He told me to uninstall TFTP2.EXE and activate  TFTP on my windows 10 laptop.
    After that i run CMD and type TFTP -i 192.168.1.1 PUT R7000-V1.0.9.18_1.2.27.chk
    This is for me the solution. My R7000 is working again.
  • If your willing to open the router up you reflash the router with the use of a serial cable there are many videos on the web that show how to this may be your only chance to sve the router if you can not access routervia a lan port. I would clear the nvram before you refash the router there still may old data in it causing poroblems.
    • BlueWonder's avatar
      BlueWonder
