pgkool
Dec 15, 2015Tutor
NAT for different subnet
I have a nighthawk R7000, and behind it a cisco switch which had different VLANs configured under separate subnets. The default subnet for the r7000 is 192.168.1.0/24, but I also have a 192.168.3.0/2...
- Dec 15, 2015
I heard from another poster that Netgear quietly removed support for NATing traffic from other local subnets. I think the reason they gave him was something like it was too complicated for users?!?
Anyway, you are outta luck with stock firmware. Fortunately for you, there is rich support for the R7000 by 3rd party firmware and I'm pretty sure they can all handle NAT of other subnets. Pick one (e.g. DD-WRT, AsusWRT-Merlin, Tomato) and have fun.
TheEther
Dec 15, 2015Guru
pgkool
Dec 15, 2015Tutor
Thanks, that was what I was presuming...sneaky sneaky Netgear.
Anyways, I just spent the last few hours installing AsusWRT-Merlin on my R7000 and it now is able to NAT other subnets!
Thanks a bunch TheEther!
