RusselAD
Feb 10, 2014Aspirant
NAT issues on Xbox One
NAT type stays strict no matter what I try. I gave up on phone support and live chat so I am hoping someone on the forums can help me out. After spending 2 days with netgear support and nothing.. ...
- Feb 12, 2014Don't use DMZ and port forwarding at same time on single device
Lexist2112
Feb 11, 2014Luminary
If the Xbox1 was configured to another router prior to the R7000, I would reset and clear ALL network config on Xbox1. Unplug the R7000 and power cycle, let it grab the signal from your modem, them turn on the xbox and config.
Are you connected wired or wireless???
If that doesn't work I noticed your on the latest FW. I used it for 2 days when I realized wireless strength was degraded, I rolled back to FW .164. Everything seems to work well on the wireless on FW .164.
Hopefully by the end of the month Netgear should release a new FW and today MS is releasing a 2 part Xbox1 update. Hopefully some wireless tweaks for the X1. From what I have heard they have been working with Dlink on "issues".
Let us know:)
Let us know:)
