RusselAD
Feb 10, 2014Aspirant
NAT issues on Xbox One
NAT type stays strict no matter what I try. I gave up on phone support and live chat so I am hoping someone on the forums can help me out. After spending 2 days with netgear support and nothing.. ...
- Feb 12, 2014Don't use DMZ and port forwarding at same time on single device
Mikey94025
Feb 12, 2014Hero
Disclaimer - I know nothing about an Xbox One or NAT type and was curious. The solutions seemed to involve port forwarding to the device. Do you have more than one public IP from your ISP? It sounds like until Xbox Live allows devices to use various public ports other than 3074 you're stuck with strict as they cannot be individually addressed from the outside.
http://forums.xbox.com/xbox_forums/xbox_support/f/9/p/1471361/3671451.aspx
