Retired_Member
Jun 28, 2021Need help pls
i just got my xr300 today and i have no idea about bridge mode. I don't know how it work
can i use xr300 with my family xfinity modem/router combo without putting in bridge mode for gaming ps5.
using xr300 without bridge mode ,will it causing problem with xfinity wifi? i can’t the disable xfinity wifi because my family want to use xfinity wifi but it too slow for my ps5. . can i use xr300 without putting in bridge mode
sorry about my English.
- Retired_Member
Help pls
what actual gatewa is it from xfinity?
did you try putting the netgear IP address into the xfinity's dmz?
or putting the netgear into access point mode
- Retired_Member
Xfiniity TG1682G'
- plemansGuru - Experienced Userdid you try putting the netgear IP address into the xfinity's dmz?
