iFrog's avatar
iFrog
Guide
Feb 26, 2019
Need help sorting out settings with NightHawk R7000 regarding local Network setup
Hi all, I'm new to the community.  Typically I don't use forums to solve issues unless I can't find a solution indipendently.   First a little background:  I have generally been an AirPort Extr...
  • iFrog's avatar
    iFrog
    Mar 06, 2019
    I'm making one more post to this thread to say I've resolved the issue.
    I have chosen to stick with DD-WRT on the R7000 over the Negear stock firmware.  The issues I mentioned in the above post regarding wireless speed turned out to not be related to the router, or DD-WRT, but rather the device being connected to the wrong wireless channel.  In this case (2.4, instead of 5GHz.). After resolving that little issue, and putting the latest DD-WRT firmware on, the router has been rock solid.
    Basically what I wanted in a router was the same choice I would get with any computer.  The hardware, and the choice of which OS to put on it.
    In this case, the R7000 Hardware+DD-WRT seems to be a good solution.
