ironchuck
Jan 29, 2017Aspirant
Netflix gives me "unblocker or proxy" error
Until a couple of days ago, everything was working fine. Today I still have internet connection but Netflix doesn't work because it says I'm using unblocker or proxy, which I am NOT. Everything in the IP/DNS config is automatic. I have tried it on several devices on my network (smart TV, tablets) and result is the same. To check if error was with the router or modem (or ISP), I connected directly to modem and found that Netflix works OK connected to modem, therefore I have to conclude the problem is with my Nighthawk router. I have no idea what to do. Please help.
I live in Panama and Netflix account is local.
Firmware V1.0.7.6_1.1.99
- Ok so after two days of trying everything I finally came to a "solution" which was to reconfigure my router as an access point. I figured that if the modem/gateway had no trouble streaming Netflix, the fix was sort of turning the Netgear router into nothing more than a broadcast station. Anyway, everything seems to be working in good order now.
Perhaps try a factory reset of the router, and reconfigure it.
- ironchuckAspirantOk so after two days of trying everything I finally came to a "solution" which was to reconfigure my router as an access point. I figured that if the modem/gateway had no trouble streaming Netflix, the fix was sort of turning the Netgear router into nothing more than a broadcast station. Anyway, everything seems to be working in good order now.
