Jpitts1982
May 13, 2021Aspirant
Netgear ac1750 port forwarding not working
I am trying to setup an arma 3 server and no matter what I try the port forwarding will not open the ports. Here is how I have things setup.
Arris sb8200 modem
Modem shows security type is dpi+(dont know if this matters as it is something the ISP has set and I cant change it even if I wanted to.)
Netgear ac1750 router
Firewall disabled on router
Firewall disabled in windows
Static ip set on pc (192.168.1.6)
Port forward set to 192.168.1.6 port 2302 udp/tcp
Upnp disabled
Arma server up and running
Port test shows 2302 closed. Port test from outside the network also shows closed.
Tried without ports set and upnp enabled and still ports are closed.
What is going on here? I can provide pics of all settings if that will help.
Arris sb8200 modem
Upnp disabled
- So I plugged the computer directly into the modem and tested ports again with the arma server running and still it says the port isnt open. Windows firewall is off and no other firewall software is used. Does this mean I might need to call comcast and see if it's something on their end?
> Arris sb8200 modem
Simple modem. Should be harmless.
Not a model number. Look for "Model" on the product label.
I don't know what that means to you. What does Netgear call what you
did?> Static ip [address] set on pc (192.168.1.6)
How, exactly?
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address. Either one should fix the address of a
device, but some implications are different.Generally, using DHCP address reservation (on the router) is simpler
to manage.> Port test shows 2302 closed. [...]
What kind of "Port test"? At which address? From where? As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.> [...] I plugged the computer directly into the modem and tested ports
> again [...]"tested ports" _how_, exactly?
> [...] with the arma server running and still it says the port isnt
> open. [...]"it"?
> [...] Does this mean I might need to call comcast and see if it's
> something on their end?Unlikely. Your ISP can't stop your local activity, and it's unlikely
to stop your external activity.
For the usual problems with port forwarding, see:- Yea... think I'll wait for someone else to help that doesnt always have a condescending attitude when they try to help someone..
