rrkrrk34's avatar
Sep 27, 2016
Netgear Genie App Not Displaying Traffic Meter Numbers Correctly with IOS 10
Ever since I updated my Ipad Air 2 and Iphone 5 to IOS 10.0.1, the Genie app on those 2 devices won't display the Traffic Meter numbers--the numbers are blocked out. Both devices have been updated to IOS 10.0.2 and the numbers still don't display properly. I uninstalled and reinstalled the Genie app on both devices and the numbers are still blocked out. I tried an old Ipad 2 which isn't updated to IOS 10 and my Windows 10 desktop PC and the Genie Traffic Meter displays the numbers correctly. I called Netgear support, but they weren't aware of this issue and so far don't have a solution. Anyone encountered this issue on their Apple devices? Thanks! Another question--is there any way through the Genie app to have it tell me the amount of bandwidth/data usage per device rather than just in total for all devices? Thanks again!
  • Hey All
    I already have forwarded this to our engineering team.
    There was another user who have submitted the same case.
  • Retired_Member's avatar
    Retired_Member
    usage cannot be broken down to a device
    • rrkrrk34's avatar
      rrkrrk34
      Tutor
      Thanks for that piece of the answer. Here's a pic of what the Traffic Meter looks like on my Ipad Air 2 and Iphone 5 with IOS 10.
        Retired_Member
        Have you checked the router via WEB Gui did you enter the ISP limit
  • This error was introduced with IOS 10, and I am sure everybody who uses the Genie app on iPad/iPhone to check the traffic meter have the same problem. To correct this,  Netgear must update the Genie app for IOS 10 (I also have an Android tablet; on this the traffic meter is correct).
    • rrkrrk34's avatar
      rrkrrk34
      Tutor
      Thanks all for the replies. I haven't entered the data cap amount in on traffic meter yet. But it's probably right that Netgear needs to update their app to accomodate IOS 10.
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        Hey All
