bw2124's avatar
bw2124
NetGear Nighthawk R7000 VPN Service grayed out
Hi Guys,
Networking noobie here. I am trying to enable my VPN service for my laptop and my phones but I see here that the service is grayed out..
Would you guys know what I can do to enable my VPN service? This service definitely comes enabled with the model I have bought - Nighthawk AC1900 Smart WiFi Router.
Thanks a lot.
  • If it's in AP mode, try setting it back to router mode, disable DHCP and any WAN stuff (if required)  plug into a LAN port instead of the WAN and re-try. It will still be in router mode but acting as an AP...Make sure you give it an IP address so that it can be managed..
  • I have the same problem, but in an older thread it shows that when the router is in AP mode, the VPN is not available.   I dont have a solution, I am also searching for this "paint by numbers set up" for the same router...Im having trouble getting on the DD-WRT set up that everyone points to ....but how does it work..I must be missing something...
    • netwrks's avatar
      netwrks
      Master
      • wongr69's avatar
        wongr69
        Thanks ...can you point to a thread that does a step by step for DD-WRT flashing on the R7000?  I want to load the PIA VPN on the router and I find it so confusing being a newbie.
