andreicri78
Oct 19, 2022Aspirant
netgear nighthawk r9000
Hello,
I have a Netger Nighthawk x 10 router (R9000) and all of a sudden I am unable to connect via WIFI as the router does not broadcast the wifi anymore. The wifi signal is active via the button as I can see the LEDs blinking, but no WIFI signal broadcasted. On LAN it works perfectly. Any ideas on how to fix this?thanks
Have you logged into the router (hardwired) to see if the ssid has changed?
Or if the ssid broadcast was disabled?
- andreicri78Aspirant
Hello. Both are active and broadcasting. I have checked that in the first place. Nothing has changed. Any other ideas?
Simple factory reset and reinstall?
