SuperHyphen's avatar
SuperHyphen
Netgear Nighthawk X6 R8000 - Factory Reset - Serial Number Missing
I recently inherited the Netgear Nighthawk X6 R8000 and its missing the label with all the information including the serial number.
I already hit the factory reset button and I am directly connected and tried to access the gateway 192.168.2.1.
I get the admin login screen, which I enter in the default admin password combo, then it asks for a Router Password Reset:
"We can help you reset your router's admin password. You need your routers serial number, which can be found on the router label. Enter your routers serial number in the field and click the Continue button."
Not sure how I can continue without the serial number as the label is not attached to the router.
Please help me.
  • FURRYe38's avatar
    Try a different browser. MS Edge, Firefox or Opera,
    Be sure all browser caches are clear before the reset.
    Enter the routers web page at 192.168.1.1 not 2.1 after the reset. Be sure the press the reset button for 10-15 seconds then release.
    • SuperHyphen's avatar
      SuperHyphen
      After resetting the device 3 times. I am now able to get into the setup screen to continue the initial setup of the router.
      This was a bit frustrating to say the least.
      I am in the admin portal, question is where can I find the serial number in the admin portal?
      I would like to not repeat the process the next time I need to run through a reset.
      Thanks,
