skynet2001's avatar
skynet2001
Netgear R 7000 Lan Ports not working
Hello who can help
My R7000 does not use lan ports 1 and 3, ports 2 and 4 are working fine.
How can i resolve this
Thanks in advance
  • plemans's avatar
    1. what firmware is on the router?
    2. how long have they been not working?
    3. if you swap a device onto one of those ports, will it work?
    4. what caused it to stop working? (storm, dropped, firmware update, etc)
    5. have you tried a simple factory reset and reinstall?
    • skynet2001's avatar
      skynet2001
      Hello ,thanks for the reply:
      1. what firmware is on the router?  V1.0.11.106_10.2.100
      2. how long have they been not working? From day 1
      3. if you swap a device onto one of those ports, will it work? Changing has te same effect ,port 1 and 3 don t work, 2 and 4 do
      4. what caused it to stop working? (storm, dropped, firmware update, etc) No idea
      5. have you tried a simple factory reset and reinstall? Yes no effect
      Thanks for your help in advance
