mocolo
May 22, 2017Aspirant
Netgear R7000 External Hard Drive Issue
Hi everyone,
I have the Netgear R7000 Nighthawk and I'm trying to connect a Western Digital My Book 4TB 2.5 USB 3.0 External Hard Drive (WDBBGB0040HBK-NESN). I am having great trouble. I essentially cannot get it to appear on my network at all, or able to find the hard drive on my computer.
I'm using a Macbook Pro 15" running the latest OS. I have no trouble accessing and using a WD My Book Live which I have connected via ethernet into the hard drive.
I have tried plugging it into both the USB 3.0 on the front and 2.0 on the back. I have tried messing around with the ready share settings. Nothing works. I have tried reformatting the hard drive from ExFAT to Mac OS Extended. Does not work.
Can anyone please help me?
Thanks so much in advance!
Hi James,
I figured out a solution right after I posted the message to the forum, so I didn't try the method you sent. What ended up working for me was that I reformatted the external hard drive from ExFAT to NTFS. As soon as I did that, I had no problem plugging it into the USB 3.0 port and accessing the drive via ready share.
- JamesGLNETGEAR Employee Retired
Hi mocolo,
Will the router detects the drive? Can you see it on the UI under ReadyShare? If yes, try this KB.
https://kb.netgear.com/19948/Map-to-a-ReadySHARE-Drive-in-OS-X-with-Auto-Reconnect-after-Reboot
Hi mocolo,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- mocoloAspirant
Hi James,
