nexus024
Jun 18, 2014Tutor
Netgear R7000 WAN Throughput
I am really interested in purchasing this router, but I have a concern that it can't handle a 1 Gbps connection. I recently got 1Gbps fiber and looking to purchase a router to handle that speed of a ...
- Jun 19, 2014You may be interested in contacting the guy that posted this message on the ddwrt forum. He is claiming close to Gb speeds on stock. No idea of his setup or if he is using SPI or not.
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=901721#901721
FlavioT
Dec 02, 2014Novice
sutedy wrote:
What is firmware version and settings for router?
I'm using the current FW V1.0.3.80_1.1.38, the only relevant change after the factory reset was to set NAT Filtering to Open. I did not enable QoS.
dantheman61
Nov 13, 2015Aspirant
i am thinking about getting the r7000 and was wondering what speeds do you get with qos on?
- JamesGLNov 18, 2015NETGEAR Employee Retired
Hi dantheman61,
The speed depends on the priority you have set. If its per device or per application. The higher the priority the more bandwidth the device or application receives.
JamesGL
Community Team
