nexus024
Jun 18, 2014Tutor
Netgear R7000 WAN Throughput
I am really interested in purchasing this router, but I have a concern that it can't handle a 1 Gbps connection. I recently got 1Gbps fiber and looking to purchase a router to handle that speed of a ...
- Jun 19, 2014You may be interested in contacting the guy that posted this message on the ddwrt forum. He is claiming close to Gb speeds on stock. No idea of his setup or if he is using SPI or not.
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=901721#901721
nexus024
Jun 18, 2014Tutor
I currently have a WNDR3700 and looking to upgrade to a router that supports 1 Gbps from the WAN -> LAN. Yes, I believe they support ipv6 but I have not used it. I have not tested any routers yet. I would like to find one here online doing some research into which one will support this speed.
