nexus024
Jun 18, 2014Tutor
Netgear R7000 WAN Throughput
I am really interested in purchasing this router, but I have a concern that it can't handle a 1 Gbps connection. I recently got 1Gbps fiber and looking to purchase a router to handle that speed of a ...
- Jun 20, 2014You may be interested in contacting the guy that posted this message on the ddwrt forum. He is claiming close to Gb speeds on stock. No idea of his setup or if he is using SPI or not.
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=901721#901721
nexus024
Jun 18, 2014Tutor
This is fine. I just want to be sure the netgear stock firmware can handle it. As the link above suggests, even the netgear firmware maxes out at 450Mbps with ipv4 and NAT. I just need to verify if this is the case or not.
