nexus024
Jun 18, 2014Tutor
Netgear R7000 WAN Throughput
I am really interested in purchasing this router, but I have a concern that it can't handle a 1 Gbps connection. I recently got 1Gbps fiber and looking to purchase a router to handle that speed of a ...
- Jun 19, 2014You may be interested in contacting the guy that posted this message on the ddwrt forum. He is claiming close to Gb speeds on stock. No idea of his setup or if he is using SPI or not.
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=901721#901721
JAMESMTL
Jun 18, 2014Novice
I really do suggestion you read the test methodology used at smallnetbuilder as you may be surprised that your experience does not match your expectations.
From testing procedure:
Upgraded to latest firmware
Reset to factory defaults
QoS features disabled (if present)
LAN client put into DMZ
SPI disabled (optionally, if router allows)
The last two points require some explanation. The LAN client is put into DMZ because it is the fastest and easiest way to allow WAN to LAN traffic and test results from the WAN IxChariot endpoint to traverse the router under test's NAT firewall. Alternatively, the specific ports used by IxChariot could be opened in the router under test's firewall. Note that since the router DMZ function is just a special case of port mapping, i.e. all ports and protocols opened to the specified LAN IP address, this does not affect router performance.
As this is not how most people use their router, I feel the testing results could be misleading. With Gb wan there is no need for qos however I doubt you would have one and only one computer and that it will be placed in the DMZ. I also suspect that most people will be running SPI as nat is not a firewall. I am a big fan of this router however I think real world thoroughput is closer to 600 Mbs from what I have read.
