nexus024
Jun 18, 2014Tutor
Netgear R7000 WAN Throughput
I am really interested in purchasing this router, but I have a concern that it can't handle a 1 Gbps connection. I recently got 1Gbps fiber and looking to purchase a router to handle that speed of a ...
- Jun 19, 2014You may be interested in contacting the guy that posted this message on the ddwrt forum. He is claiming close to Gb speeds on stock. No idea of his setup or if he is using SPI or not.
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=901721#901721
nexus024
Jun 18, 2014Tutor
I did read that from their test procedure, however they did say that SPI had little effect on throughput...
"But we have found that disabling SPI is simpler and in most cases does not affect router throughput."
