21kidsanddogs
Jun 05, 2025Aspirant
Netgear R7000
i was getting buffering - checked the modum and that was good- unplugged the router - finally reset it - but when i try to connect the router to my computer with the ethenet cord the routerlogin -...
Jun 05, 2025Guru - Experienced User
Does connecting to 192.168.1.1 work?
What FW version is loaded?
How did you reset the router? Press the back button for 15 seconds then release?
