R7000P
7 TopicsNeed recommendations
Normally I rent the equipment from my ISP but I hate eero (which is the only option for renting) and want to get away from it because it's only controlled via apps and I don't do apps. I need some recommendations. Here is how I plan to use the equipment: Whatever router I go with, I need to be able to connect to it via my desktop computer by typing in the router's ip address the old-school way. I like to be able to turn wireless on or off when I want to, or change the signal strength, and I only want to access it via desktop computer. First I plan to purchase modem and router, or a modem/router combo, to use with ISP #1, who has fiber in the ground that connects to a box that switches to coax cable for final delivery to the house, and therefore we would connect said equipment to the coax. Coax and ethernet cable are in the walls. Then, we will be switching to ISP #2 later; they are currently installing fiber in our neighborhood, and they may end up running fiber all the way to the house so that coax is no longer used for final delivery. If this is the case, will I need to change my equipment or is there equipment I can buy that can do both? And I've read that maybe I should buy modem and router separately instead of doing them as a combo; why is that? Oh and our speed will either be the 500 or 1000 plan. Thanks for any advice provided, much appreciated!166Views0likes6CommentsR7000P V1.3.3.140_10.1.75 forward sip message , don't change ip.src
Hello everyone, I am developing a VOIP software system and I have noticed an issue: the Netgear R7000P router does not modify the value of the ip.src field of the UDP message when forwarding SIP (UDP). The specific situation is shown in the following picture:132Views0likes5CommentsNetgear R7000
i was getting buffering - checked the modum and that was good- unplugged the router - finally reset it - but when i try to connect the router to my computer with the ethenet cord the routerlogin - the page never loads not sure where to go from here - purchased in 2021 so its not that old and its been a great router with a good range to reach my back field where i monitor bluebirds with a blink camera215Views0likes3CommentsR7000P power outage fault
I recently had a power outage for all of 20 seconds and, even though I’ve had many over the years with this router, this time the WiFi didn’t work again and the name of the router started showing up as the standard name instead of what I personalised it to. That is to say, my devices SAY they are connected but there is no actual, working WiFi. I’ve done all the usual work arounds suggested online and even resorted to factory resetting TWICE and I can never get to the end of the set up process in the app. I get as far as the ‘checking cables’ part which clears but it always says there’s no internet connection despite the fact my phone is showing as connected. It suggests turning the router off and on again - which of course I have done a hundred times. I’ve checked my Internet service and that’s all perfect, as it’s displaying on the nbn modem. Firmware was up to date even before all this nonsense and shows as such in the app. It makes no sense to me why all of a sudden it chooses to blow up after a power outage when it’s survived dozens in the past. I genuinely have no idea what more I could do. I know it’s an old machine, is it just time to upgrade?144Views0likes1CommentR7960p
I just installed this router and after finally getting it set up I accidentally unplugged it and when it came back up everything went back to the factory settings and now I can't get it to connect. Is this router worth it or sounds like I just need to get another router. Any suggestions? Thanks177Views0likes7CommentsEnabling dynamic QOS on R7000P causes internet to disconnect
I've had this router for a month. For the most part, it works fine. But I've been noticing random lag spikes and disconnects while playing World of Warcraft (my wife gets them too, seemingly at random, and never at the same time they happen to me, even when we're both playing WoW together). Both of our PCs are on wired connections to the router. Per recommendations from the battle.net forums, I tried to enable Dynamic QOS on the router to see if that would help with the issue. However, as soon as I enable & apply Dynamic QOS (prompting a router reboot), all internet connectivity drops, and stays off after the router finishes rebooting. I can still access the router configuration, thankfully, but at that point all I can do to restore internet connectivity is turn Dynamic QOS off and reboot the router again. I would try Advanced QOS instead, but I can't find that anywhere in the router configuration. If it helps, I have Comcast Xfinity 100Mbps (speedtest.net says ~115Mbps upload, ~6Mbps download) using my own Motorola/Arris SURFboard SB6121 modem. I'm using the latest firmware (1.0.1.14). I can't find anyone else here or elsewhere reporting this problem. Any ideas?Solved34KViews0likes11Comments
