R7000P
13 TopicsNeed recommendations
Normally I rent the equipment from my ISP but I hate eero (which is the only option for renting) and want to get away from it because it's only controlled via apps and I don't do apps. I need some recommendations. Here is how I plan to use the equipment: Whatever router I go with, I need to be able to connect to it via my desktop computer by typing in the router's ip address the old-school way. I like to be able to turn wireless on or off when I want to, or change the signal strength, and I only want to access it via desktop computer. First I plan to purchase modem and router, or a modem/router combo, to use with ISP #1, who has fiber in the ground that connects to a box that switches to coax cable for final delivery to the house, and therefore we would connect said equipment to the coax. Coax and ethernet cable are in the walls. Then, we will be switching to ISP #2 later; they are currently installing fiber in our neighborhood, and they may end up running fiber all the way to the house so that coax is no longer used for final delivery. If this is the case, will I need to change my equipment or is there equipment I can buy that can do both? And I've read that maybe I should buy modem and router separately instead of doing them as a combo; why is that? Oh and our speed will either be the 500 or 1000 plan. Thanks for any advice provided, much appreciated!192Views0likes6CommentsR7000P V1.3.3.140_10.1.75 forward sip message , don't change ip.src
Hello everyone, I am developing a VOIP software system and I have noticed an issue: the Netgear R7000P router does not modify the value of the ip.src field of the UDP message when forwarding SIP (UDP). The specific situation is shown in the following picture:151Views0likes5CommentsNetgear R7000
i was getting buffering - checked the modum and that was good- unplugged the router - finally reset it - but when i try to connect the router to my computer with the ethenet cord the routerlogin - the page never loads not sure where to go from here - purchased in 2021 so its not that old and its been a great router with a good range to reach my back field where i monitor bluebirds with a blink camera226Views0likes3CommentsR7000P power outage fault
I recently had a power outage for all of 20 seconds and, even though I’ve had many over the years with this router, this time the WiFi didn’t work again and the name of the router started showing up as the standard name instead of what I personalised it to. That is to say, my devices SAY they are connected but there is no actual, working WiFi. I’ve done all the usual work arounds suggested online and even resorted to factory resetting TWICE and I can never get to the end of the set up process in the app. I get as far as the ‘checking cables’ part which clears but it always says there’s no internet connection despite the fact my phone is showing as connected. It suggests turning the router off and on again - which of course I have done a hundred times. I’ve checked my Internet service and that’s all perfect, as it’s displaying on the nbn modem. Firmware was up to date even before all this nonsense and shows as such in the app. It makes no sense to me why all of a sudden it chooses to blow up after a power outage when it’s survived dozens in the past. I genuinely have no idea what more I could do. I know it’s an old machine, is it just time to upgrade?160Views0likes1CommentR7960p
I just installed this router and after finally getting it set up I accidentally unplugged it and when it came back up everything went back to the factory settings and now I can't get it to connect. Is this router worth it or sounds like I just need to get another router. Any suggestions? Thanks206Views0likes7CommentsR7000P: Der Router funktioniert nach Firmwareupdate nicht mehr
Hallo zusammen, ich habe ein Problem mit meinem Router. Ich habe über die Web Oberfläche ein Firmwareupdate gestartet. Nach etwa einer Stunde wollte ich schauen, ob das Update durch gelaufen ist, kommte aber nicht mehr auf die Oberfläche drauf schauen. Hatte auch keine Internetverbindung mehr und erreichte auch keine anderen Teilnehmer mehr im Netzwerk. Ein Ping zum Router ging noch durch. Daraufhin habe ich den Router über die Power Taste aus und wieder ein geschaletet. Jetzt funktioniert leider gar nichts mehr. Weder ein Ping noch eine Netzwerkverbindung zu anderen Geräten. Die LEDs der Netzwerkports blinken noch und die Power LED blinkt ebenfalls. Laut Anleitung bedeutet dies eine Fehlerhafte Firmware:( Also probierte ich den Router auf Werkseinstellung zurück zu setzten indem ich ca. 10 Sekunden die Resettaste betätigte. Dies brachte aber leider keine Verbesserung und der Fehler bleibt weiterhin bestehen... Hat jemand eine Idee, wie ich ohne Weboberfläche die Firmware neu auf den Router bekomme? Über einen USB Stick? Besten Dank und viele Grüße TobiasSolved2.9KViews0likes3CommentsR7000P: Download- und Upload-Geschwindigkeit
Hallo Ihr, lt. Vertrag mit meinem Provider habe ich vom Modem weg direkt auf den PC 50 Mbps Download- und 5 Mbps Upload-Geschwindigkeit. Wenn der Nighthawk R7000P zwischen Modem und PC situiert ist, also angeschlossen, verringern sich die Download- und Uploadgeschwindigkeiten um die Hälfte: 25 Mbps/2 Mpbs. Wieso passiert das, gibt es spezielle Einstellungen am Router, die ich vornehmen muss, damit 50/5 erzielt werden kann. Lt. Provider ist das Modem ok. Freue mich auf eine positive Antwort. Danke und beste Grüße.Solved2.1KViews0likes3CommentsR7000P - DnsMasq heap buffer overflow vulnerability - Avast CVE-2017-14491
Hallo zusammen. Habe auf meinem Netgear R7000P, gekauft September 2018, folgende Sicherheitslücke festgestellt : CVE-2017-14491 DNS Port 53 diese wurde mir durch AVAST mitgeteilt. Habe die neuste Firmwareversion V1.3.1.44_10.1.23 auf dem R7000P Habe den Netgear Support schon angefragt doch diese konnten oder wollten mir nicht helfen. Netgar hat mich auf www.bugcrowd.com verwiesen, doch da habe ich zuwenig Erfahrung. Kann mir von Euch jemand helfen was ich da am besten tun muss? Den Port 53 einfach sperren? Müsste da nicht Netgear ein neue Firmeware bereitstellen? Vielen Dank eikeiSolved6.6KViews0likes5CommentsR7000 und R7500 zu je einem Access Point konfigurieren
Guten Tag Ich möchte meine beiden W-LAN-Router (R7000 und R7500) zu je einem Access point konfigurieren. Im Moment habe ich folgendes Netz-Werk zu Hause: Im Technik-Raum des Hauses steht das Modem. Von dort gehen 2 LAN-Kabel weg, ein LAN-Kabel zur Wohnung (1. Obergeschoss) und das andere zum Büro(Untergeschoss) Im Büro habe ich den W-LAN-Router R7000 im Einsatz In der Wohnung habe ich den W-LAN-Router R7500 im Einsatz Was ich ändere: Im Technik-Raum des Hauses einen LAN-Router einsetzen. Vom Modem geht LAN-Kabel zum LAN-Router, von dort gehen die beiden LAN-Kabel zu Wohnung und Büro. Die beiden W-LAN-Router (R7000 und R7500) möchte ich als Access Point konfigurieren. Meine Frage dazu: Kann es zu Konflikten zwischen den beiden Access Point (R7000 und R7500) kommen ? Muss ich bei einem evtl.etwas anders Konfugurieren ? Danke für die AntwortenSolved3.9KViews0likes1Comment
