mediatrek
Feb 24, 2016Virtuoso
Netgear R7500 & R7500v2 need updated SSL Key in a firmware update
No this is not a "feature request" posting, but another highlight of Netgear not being ontop of their own "active" (not EOL) product line. The original Netgear R7500 and the revision R7500v2 need...
- Mar 18, 2016
Per engineering, just update the QoS database and there's no need for any FW update to correct the SSL key.
Can you guys confirm?
avtella
Mar 27, 2016Prodigy
The R7500v1 is EOL not the v2. As for you WiFi issues try downgrading the firmware.
- CstrittMar 28, 2016Aspirant
The router itself doesn't say anything about the version but when I log into the firmware via router login.com it states R7500v2. That is why I believe I have the v2. Am I correct in this assumption?
thank you for responding. I really do appreciate it.
Cstritt
