Eckhartfamily5's avatar
Sep 05, 2017
Netgear R9000
I have the router setup with an Arris modem/Xfinity. The main computer is a Mac with is connected by ethernet. I have devices connected to 2 of the bands. My computer, phones, ipad are connected to the 2.4. I have the tv's, kids' computers (gamers), ps3 etc on the 5. It seems the main computer, though connected by ethernet cat6 is constantly losing connection. It doesn't happen while I'm in the middle of anything. It happens when I come back to it. Can't login into www.routerlogin.net to look at it. IPad goes out also. Can usually use my phone. If I open Network Preferences it show both the Ethernet and WiFi are connected, but I can't open a browser or login. I try clicking on the Ethernet and renewing the DHCP lease. Nothing. I can't have this issue every time I come back to the computer. The rest of the household seems fine with their connections while this is going on.
  • I ended up calling support. Apparently there was a wrong IP address in the wrong place that was causing issues. I ended up doing a hard reset and using Genie to set up again. Seems much better for now.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, @Eckhardfamily5
    Did you try to other ports on the router?
    How about changing the cable?
    Can you check if you'll experience the same problem if you use a different device connected through wired?
    It might be the LAN card on your Mac computer.
    • Eckhartfamily5's avatar
      Eckhartfamily5
      • ElaineM's avatar
        ElaineM
        Great to hear. Thank you for the update!
