Priost
Jul 25, 2017Aspirant
Netgear RX7500 2,4 Ghz network not working anymore
Hello together, some days ago, I saw on my router, that there is a update. After I installed the newest version, which is V1.0.0.108, I first found out, that the connection speed for all clients...
- Aug 04, 2017
Finally found it out.
It seems that the router was missinterpreting the WLAN WPA key, I entered. Maybe a unvisible character or somthing.
What I now did:
- Stopped broadcasting of SSID (For security reasons caused by next step ;-))
- Took awway all encryption methods and applied this settings
- After apx. 5 minutes, I changed everything back to the config I wanted
Now it is working fine
JamesGL
Jul 27, 2017NETGEAR Employee Retired
Hi Priost,
Try changing the channels of your wireless network.
- PriostJul 28, 2017Aspirant
Hi,
this I tried 5 times minimum.
To give it a new try, I did it just a minute ago. The WLAN was reachable for not even a minute. After then my sniffer was not able to find it anymore and it disappeared on al clients.
- JamesGLAug 03, 2017NETGEAR Employee Retired
Hi Priost,
Try to reload the firmware and reset.
- PriostAug 04, 2017Aspirant
What I now did:
