Priost
Jul 25, 2017Aspirant
Netgear RX7500 2,4 Ghz network not working anymore
Hello together, some days ago, I saw on my router, that there is a update. After I installed the newest version, which is V1.0.0.108, I first found out, that the connection speed for all clients...
- Aug 04, 2017
Finally found it out.
It seems that the router was missinterpreting the WLAN WPA key, I entered. Maybe a unvisible character or somthing.
What I now did:
- Stopped broadcasting of SSID (For security reasons caused by next step ;-))
- Took awway all encryption methods and applied this settings
- After apx. 5 minutes, I changed everything back to the config I wanted
Now it is working fine
JamesGL
Jul 27, 2017NETGEAR Employee Retired
Hi Priost,
Try changing the channels of your wireless network.
JamesGL
Aug 03, 2017NETGEAR Employee Retired
Hi Priost,
Try to reload the firmware and reset.
- PriostAug 04, 2017Aspirant
What I now did:
