ethonkent's avatar
ethonkent
Follower
Jul 28, 2023
Netgear wifi 5 mesh vs wifi 6 router
I live in a mid-size condominium and proper now i have Netgear Nighthawk AC1900 which serves as my modem and router. It is been getting sluggish currently and would love to update it.
Am no longer certain if going with a Nighthawk AX6200 router and a Nighthawk DOCSIS three.1 modem could be a better answer over going with a 2-1 Orbi Tri-band system.
My internet pace is 100mb and the router/modem is in the residing room and that i would love to get solid connection in my room even if the door is closed.
  • If you want seamless WiFi roaming, then you can't avoid the Orbi. For everything else, considering your speeds, the router+modem combo is fine.
    • michaelkenward's avatar
      michaelkenward
      I moved on from Orbi to the MK Mesh routers recently, wipes the floor with Orbi.
      • FURRYe38's avatar
        My 8 and 9 series Orbi work far better than the MKs IMO.
  • FURRYe38's avatar
    Whats the size of the condo?
    Size of home can point to how many satellites maybe needed.
    There is Orbi and Nighthawk MESH systems available.
