GymRat
Dec 29, 2016Follower
NetWork Extend with router AC2600 Nighthawk
My question is am I using my AC2600 router in the best way possible, given recent network changes in my house? Recently I upgraded my home router from a LinkSys to the NetGear AC2600, which has n...
- Jan 03, 2017
Hi GymRat,
If you want to have a better range, I would suggest to set the Ubee modem.router to modem only or bridge mode and let the R7800 manage the network. In that way the R7800 is the only router that will handle the connection. Better range and better speed.
JamesGL
Jan 08, 2017NETGEAR Employee Retired
Hi GymRat,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
