Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited DNS Probe/Proxy fix. Enable IPv6 Auto if you continue to see DNS Probe or Proxy messages in browsers.
Download Link:
R7900P: <End Of Life
https://www.netgear.com/support/product/R7900P.aspx#download
R7960P:
https://www.netgear.com/support/product/R7960P.aspx#download
R8000P:
https://www.netgear.com/support/product/R8000P.aspx#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit:
https://www.netgear.com/support/product/R7900P.aspx#docs
https://www.netgear.com/support/product/R8000P.aspx#docs
https://www.netgear.com/support/product/R7960P.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how it works for you...
Also the R7900P is now EOL: https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Top-NETGEAR-FAQs-Support-and-End-of-Service/td-p/1881104/jump-to/first-unread-message
- Retired_MemberHi I’m looking for the new beta fw for the R7760P. Does this firmware fix the dns probing issue? I’m currently on 1.4.1.68 as it’s the only one that doesn’t have this issue.
Please re-confirm your router model # please.
Retired_Member wrote:
Hi I’m looking for the new beta fw for the R7760P. Does this firmware fix the dns probing issue? I’m currently on 1.4.1.68 as it’s the only one that doesn’t have this issue.- tchesketAspirant
Hello,
I have a Nighthawk R7900P, having the same "invalid MAC address" issue when trying to reserve addresses. I have it on V1.4.4.94_1.3.56. Can I also have a link for the new firmware that fixes this issue please?
Thanks
- Wayne_BAspirant
Hello,
I have a Nighthawk R7960P and I’m having the "invalid MAC address" issue when trying to reserve addresses. It is currently running the V1.4.4.94_1.3.56 firmware.
Can I get the new beta firmware that fixes this issue please?
Thanks,
Wayne
- bloha1Aspirant
Two or three weeks ago saw an article about some massive security flaw with old firmware version on the R8000OP. Figured id update to V1.4.4.94_1.3.56. Did that, now have been having the dreaded "Hmm. We are having trouble finding that site" issues. And even some apps have started to report connectivity issues. Attempted to add the IPv6 auto settings and those helped some, but didnt fix it completely and still have the above error show up, and some programs complain.
If possible please send the R8000P beta firmware.
Sent.
can i please get the Beta version of r8000p
- Retired_Member
Hi,
For when the final version with everything corrected?
Thanks
- ZeustopherInitiate
Nighthawk R7960P running V1.4.4.94_1.3.56 having the "Invalid MAC Address" error... Please send me the beta firmware.
And has there been any word when this will be made "official"? This thread has been reporting these issues since November.
Sent.
- Retired_Member
Hello,
I am completely disappointed with NetGear's incompetence.
I have the very expensive R8000P and when a new update comes out the router gets worse.
I´m tired of this situation that lasts for months, I solved all the problems with a new TP-LINK Archer AXE75 router.Thanks.
- crbowmanAspirant
R8000P - Please send beta update
- nglcabAspirant
Hi,
I have a Nighthawk R7960P running V1.4.4.94_1.3.56 having the "Invalid MAC Address" error as well
Could I please get the beta firmware.
- jgo304Aspirant
If anyone could provide me with the Beta Firmware I would appreciate it!
- RaptorialandAspirant
I updated my firmware now nothing works...
Steam does not load (have to reload it 5 times)... and every new site i open has a dns error.
I know this issue already after fighting with it and solved it with 6to4 tunel.
I am an absolute noob and i dont know what i am doing with all this settings... i dont know what they mean and i dont know what they do.i bought an expansive router and now i have to infest my freaking freetime to understand all that bs!
Also why just upload the beta in the download section. NO you have to login.
I tried my password 4 times... slowly ... did not work... reset the password... type in new password (ohhh password is old try a new one)
Is anything working with this company.
Please just send me the beta or tell me if the update will be released in the next weeks so i dont have to learn how to manually install a firmware (and prob. learn how to roll back to an old firmware because nothing netgear is releasing works)
sry 4 being so angry but i really have enough of it now.
(i also used a pihole - yeah only follewed youtubetutorials and installed it somehow and get it to work... it worked well until i first updated the firmware of the router. because i am a noob i thought it is an issue with pihole. so i wasted weeks without thinking about the router... later i found out it was of course the routerfirmwareupdate. solved it - as already told - with 4to6 tunel option.
Oh god i wasted so much time on this already... just give me something that works. Its 2023 - all i want is freaking working internet on my Windows pc (Every other android tablet, phone, mac, ... works!)
Thank you- FURRYe38Guru - Experienced User
What model router do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Iv'e switched to 6rd for any IPv6 tunneling configurations. I use Hurricane Electric.
- lmnope1Tutor
Can I please have a copy of the R7960P beta firmware?
Thank you
Amazing to me this still hasn't been officially released.
Waiting patiently.
Waiting patiently.
Indeed. Baffling.
Makes you wonder what is going on when Netgear relies on a third party to do its dirty work.
