FURRYe38's avatar
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
  • Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited DNS Probe/Proxy fix. Enable IPv6 Auto if you continue to see DNS Probe or Proxy messages in browsers.
Download Link:
R7900P: <End Of Life
https://www.netgear.com/support/product/R7900P.aspx#download
R7960P:
https://www.netgear.com/support/product/R7960P.aspx#download
R8000P:
https://www.netgear.com/support/product/R8000P.aspx#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit:
https://www.netgear.com/support/product/R7900P.aspx#docs
https://www.netgear.com/support/product/R8000P.aspx#docs
https://www.netgear.com/support/product/R7960P.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how it works for you...
Also the R7900P is now EOL: https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Top-NETGEAR-FAQs-Support-and-End-of-Service/td-p/1881104/jump-to/first-unread-message
  • I would like the beta FW version that fixes the IP address reservation issue.
    Getting old fixing the port forwarding IP after every reboot.
    R7960
    Thank you
  • What version is the beta for the R7960p?
    Can you share a link to it?
    Others with the R8000 router have an alternative to the Netgear firmware, they can use DD-WRT as the router is compatible… unfortunately myself by having the R7960p cannot flash the custom firmware… 😞
    • RahulM's avatar
      RahulM
      Any update after this for R8000P. V1.4.4.95_22.10.25
      • michaelkenward's avatar
        michaelkenward
        For officially released updates, visit the support pages:
        Support | NETGEAR
        Feed in your model number and that page will have any software, firmware and drivers for your device.
        There is also a library of past releases.
  • FURRYe38's avatar
    @JohnMichael2014
    We can't send you any Private Messages to your account from here in the forums. You need to enabled private messaging so we can respond to you.
    • Robot_M's avatar
      Robot_M
      Hi @FURRYe38
      Could you send me by PM a link to download this beta firmware that fix this problem?
      Router model: R8000P
      Thanks
    • CSLV69's avatar
      CSLV69
      Oooooooh .... yes pls.
       @FURRYe38 Sir could you please send a copy of beta FW? Please?....
      I am unable to do ANYTHING with DHCP (as I see everyone else is having these exact same issues), more specifically whenever I try to create a reservation, or modify the details of detected devices I receive "invalid mac address" and I have to log back in again as the browser (Chrome on Win 10) then shows the stupid sad face and rain cloud (I cannot begin to communicate how frustrating finding all of these faults has been and continues to be). I am not a beta tester, if I were I'd be getting paid but instead, as a customer (for now) I rely on the manufacturer to have thoroughly and rigorously tested their own products including published firmware updates before sending to market .... at least for everyone but Netgear anyway, aparently.
      I also have problems with readyshare DLNA media server settings (not a deal breaker, I was just looking at what it could do since the hardware looked like it should be able to handle the additional workload. Im now thinking I should stick with purpose built devices instead. All-in-one type devices always seem to perform exceptionally poorly.) Never-the-less if you have updated FW that addresses some or even just one of the many short-comings this version of the R8000P AC4000 FW brings along with it, I would be very apreciative.
      Thank you sir
  • Hi!
    How could I get the beta firmware fixing the IP cable allocation? It is quite bothersome 😕
    thanks!
    • RahulM's avatar
      RahulM
      The BETA seems to have a bug. Dynamic QOS is not working. All device always gets low priority by default and Internet download and upload speed device wise is always 0 even if it is consuming data consistantly.
  • I have the R7960P.  I just ran into the DHCP Reservation / MAC address bug.  Is there a beta firmware for my router?
    @FURRYe38  could you be so kind as to PM me a link, if available.
    Thank you.
  • Hello FURRYe38 ,
    I have a Nighthawk R8000P and would be interested in the beta release as well. I am not having any luck reserving an IP address with my current version of  V1.4.4.94_1.3.56.
    Thank you,
