Garyrh66
Feb 23, 2019Apprentice
New firmware for AX8 1.0.1.56 available and not good results
Updated to the new firmware and it lowered my Wi-Fi speed. I have Comcast blast 250 Mbits. With 1.0.1.40 I was getting 300 Mbits down and with new firmware my speeds lowered to 50-70 Mbits. Back to 1.0.1.40 and speeds are back to 300 Mbits.
I found the problem. Login and change the 5g wireless channel to 153 and the mode to 2400Mbit. For some reason the new firmware changes this. All is back to normal now with my wireless speed which is back to 300Mbits.
- Monstercastle2Aspirant
Same issue here, but haven't rolled back yet.
- myerswMaster
Gush what a surprise!!
With Netgear's history of bad firmware, what did you expect?
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.- Garyrh66Apprentice
Reset set the router to factory default and it did not fix the problem
- NavymacAspirant
Just upgraded and have Comcast Blast 150 with a Comcast Modem. (CISCO DPC3941B) I was getting 118Mbits. With The firmware update, I'm getting 108 MBits. I'll keep a watch on it.
- microchip8Master
you're beta testing still. People rushing immediately to get the latest and greatest instead of waiting to mature are virtually always beta testing, especially firmware-wise
- Anonymous
Same results here too. Went from 450 to 120 and that's with an ethernet connection, not wifi.
- myerswMaster
Where I live Comcast over provisions so that my 250/20 tests more like 290/24.
What speeds do you get connected directly to the modem with a PC?
The blast speed in our area is 250Mbits down and 10Mbits up. I usually get 297 to 300Mbits down and 11 to 12 Mbits up direct from modem. Since I fixed the issue with the new firmware and now those speeds on both wired and 5g Wi-Fi.
