Gini
Jan 06, 2016Aspirant
New router and effect of changing security setting from WPA to WPA2
I am planning on upgrading our old router, and I'm seriously considering the Nighthawk AC R7000. When I do so, I plan to also upgrade our present WiFi security from WPA to the Nighthawk's default, WP...
- Jan 06, 2016
Unless it is pretty old, it should support WPA2. In the devices wireless settings it should have the option to select the encryption, and you can see if it is in the list.
Retired_Member
Jan 06, 2016Wrong!
New security will require all new logins. Be sure all clients are capable of WPA2 otherwise you'll have to use WPA/WPA2
Gini
Thank you for the prompt reply, even if it wasn't what I'd hoped to hear! I don't know how to determine whether each/every device I have can use WPA2, though. Should I opt for the less secure WPA/WPA2 to avoid any problems? Thanks again!
- rpoffenJan 06, 2016Virtuoso
- GiniJan 06, 2016AspirantI don't even recall seeing encryption choices for things like my Kindles, tablets, Roku, etc., but I did find the R7000 manual online which said the default protocol was WPA-PSK [TKIP] + WPA2PSK [AES}. That's supposed to handle older devices, too, even if that choice isn't quite as secure as just WPA2. Thanks for the help!
I think it is pretty safe to say that all smart phones, kindles, tablets, etc. support WPA2.
But setting mixed mode should be fine, the older protocols are less secure, but it takes more specialized equipment to break them, and your average hacker isn't going to go through all the neighborhoods scouring all the WiFi's looking for one to break into.
