SaintJulio's avatar
SaintJulio
New to netgear
Im planning to get a netgear and have a couple questions. Does Netgear need a modem to work or does it work as soon you connect the coax cable from the wall to the netgear will it work? Do you have to pay monthly like Xfinity for example? Im new to this and hopefully find an answer to this
    A Netgear what?
    What is the "coax cable from the wall"? It may or may not need a  modem, depending on what sort of Internet you get.
    Ask your ##Internet service provider what equipment you need. It may offer to rent of sell you something. But most will let you use your own equipment
    Xfinity is an ISP. All ISPs that I know of charge for access.
  • Yes, it needs a modem.
    No, you don't have to pay monthly. It's your equipment.
    • SaintJulio's avatar
      SaintJulio
      Thank you so much for replying
      Mind if i ask where i can buy a modem?
  • michaelkenward's avatar
    michaelkenward
    A Netgear what?
      SaintJulio
      Thanks for writing back
      I had xfinity but recently changed to fios but canceled there service not to long agoi
      Netgear i was planning to get was ac1900 router
        michaelkenward
        You'll have to sign up with someone to get onto the Internet. I'd wait until I chose that before deciding what equipment to buy.
        That's not a Netgear model number. AC1900 is not a unique Netgear model number. Some devices come with the AC tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
        AC1900 is also a somewhat ancient wifi technology from about five years ago. Does Netgear still sell that stuff?
