ajo999
Jan 10, 2015Aspirant
NG R7000 AC1900 Very slow Speed Tests
Noticed something odd with the speeds. I am getting below 10Mbps, both WiFi and wired. Before it was showing 100Mbps instead of 1Gbps, and I got speeds at around 13Mbps on my old previous router. Bu...
- Jan 12, 2015ajo999, Maybe your router MTU needs to be adjusted (common for DSL connections), this is done in the router admin page ‘Advanced’ – ‘Setup’ – ‘WAN Setup’. Here you can enter an MTU value, try a setting such as 1400 or 1492, there’s more information in the router manual page 36 onwards.
rp1p
Jan 12, 2015Aspirant
You say you have QoS enabled make sure you're not mixing up mb and kb on the input fields for up and down. In fact, disable QoS then run the speed tests. There should be no reason why you're seeing slower speeds than your older router.
