ajo999
Jan 10, 2015Aspirant
NG R7000 AC1900 Very slow Speed Tests
Noticed something odd with the speeds. I am getting below 10Mbps, both WiFi and wired. Before it was showing 100Mbps instead of 1Gbps, and I got speeds at around 13Mbps on my old previous router. Bu...
- Jan 12, 2015ajo999, Maybe your router MTU needs to be adjusted (common for DSL connections), this is done in the router admin page ‘Advanced’ – ‘Setup’ – ‘WAN Setup’. Here you can enter an MTU value, try a setting such as 1400 or 1492, there’s more information in the router manual page 36 onwards.
VE6CGX
Jan 12, 2015Master
Hi,
I'd rather try with QOS disabled.
