ajo999
Jan 10, 2015Aspirant
NG R7000 AC1900 Very slow Speed Tests
Noticed something odd with the speeds. I am getting below 10Mbps, both WiFi and wired. Before it was showing 100Mbps instead of 1Gbps, and I got speeds at around 13Mbps on my old previous router. Bu...
- Jan 12, 2015ajo999, Maybe your router MTU needs to be adjusted (common for DSL connections), this is done in the router admin page ‘Advanced’ – ‘Setup’ – ‘WAN Setup’. Here you can enter an MTU value, try a setting such as 1400 or 1492, there’s more information in the router manual page 36 onwards.
krayzie32
Jan 13, 2015Aspirant
Since I've switched to the R7000, I've had issues with my wired throughput speeds. speedtest.net results have always been 50+, but my actual DL speeds have been less than 1MB. I did the below and now my DL speeds are 4-5MB.
-Uncheck Disable SIP ALG
-Uncheck Disable IGMP Proxying
-Auto detect ipv6
Hope this helps (I'm also on the newest firmware).
-Auto detect ipv6
