Les_House's avatar
Les_House
Nighthawk 7500V2 Firmware Version 1.0.3.10 Corupted File
I have tried to download firmware Version several times on different computers.  Each time I try to unzip the file I get a message that the file is cotupted.
  • I discovered my problem.  Operator error.  I did not realize that you could not extract the Zip files just by right clicking on the file in windows 10.  I was able to unzip the file when I used the proper Windows 10 procedure.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Les_House,
    I was able to download the file without any issue. Make sure the download is completed and check the file size. In my case the file size is 22MB.
    • Les_House's avatar
      Les_House
      Each time I dowloaded the file the download was complete.  Only took a few seconds to download.  I have used Firefox, Chrome, and Opera browsers on ttwo separate Windows 10 computers.  With the same result.What was yout operating system when you did the upgrade?
        Les_House
    • JamesGL's avatar
      JamesGL
      Hi Les_House,
      Were you able to update the firmware of the router?
      • JamesGL's avatar
        JamesGL
        Hi Les_House,
        We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
